Model Name: | Spartan SR Race Boat |
Model Type: | Boats |
Model Speed: | 50+ mph with two 3-cell LiPo batteries |
Model Skill Level: | 2 |
Scale: | 1/10 |
Weight: | 5.29 pounds (2.39 kg) |
Length: | 40.8 inches (1037 mm) |
Width: | 9.5 inches (243 mm) |
Height: | 7.2 inches (183 mm) |
Drive System: | Direct drive, 4.7 mm flex cable |
Outdrive: | Adjustable aluminum |
Hull Length: | 36.5 inches (927 mm) |
Dead Rise Angle: | 26 degrees |
Beam (Width): | 9.5 inches (243 mm) |
Hull Type: | Composite Deep-V |
Servo(s): | 2056 high-torque waterproof |
Radio System: | TQi™ 2.4 GHz 2-channel transmitter with TSM® receiver |
Motor Name: | Velineon® 540XL Marine |
Motor Type: | Sensorless brushless |
Motor Weight: | 13.62 ounces (386 g) |
Motor Length: | 4.07 inches (103 mm) overall length, 3.25 inches (82 mm) can length |
Motor Diameter: | 1.42 inches (36 mm) |
Motor Shaft Size: | 5 mm |
Motor Connector Type: | Traxxas 5.5 mm bullet connectors |
ESC Name: | Velineon® VXL-6s Marine |
ESC Type: | Brushless |
ESC Case Size: | 2.28 inches (58 mm) / 2.83 inches (72 mm) / 1.81 inches (46 mm) |
ESC Weight: | 7.30 ounces (207 g) |
Motor Connectors: | Traxxas 5.5 mm bullet connectors |
Battery Connectors: | Traxxas High Current Connector |
Spartan SR requires dual 7-cell NiMH or dual 2s or 3s LiPo batteries. See full list of batteries.
Traxxas EZ-Peak® Dual 3s (2972) is recommended for easy and fast charging performance.
Parts Sub-Categories |
Spartan SR is built for speed and performance. Pull the trigger and Spartan SR immediately jumps on plane and rips across the water to its heart-pounding 50+ mph top speed! There’s nothing else like it and nothing holding you back. If a wave pitches the wrong direction, self righting is on board and within seconds, Spartan SR is back to extreme, full-throttle fun.
Self righting is more than a convenience feature, it’s an all-access pass to exploit Spartan’s full 50+ mph fury. Boaters of all skill levels will enjoy the confidence-inspiring security of self righting. There’s no need to back off the throttle or tone down the action. Just pin the throttle and Spartan SR takes care of the rest.
Spartan SR’s deep-V ABS hull carefully balances speed with agility for a truly thrilling driving experience. A new electronics layout and battery tray drastically improve handling precision by concentrating the weight inboard along the centerline. The result is razor-sharp handling, no-lift turns, and superior high-speed stability.
Grab a fistful of throttle and Spartan SR’s VXL-6s™ Marine power system transforms 22+ volts of LiPo power into furious acceleration. The high-performance prop digs in, getting the boat on plane quickly and efficiently as it slices through the water at speeds of 50 mph and beyond.
Spartan's prop gets the hull on plane quickly to reach maximum speed with the least current draw. Traxxas engineers tested countless prop configurations to find the perfect balance of performance, efficiency, and durability. Molded composite construction makes the prop light and tough, with no balancing or sharpening required.
Spartan’s rudder and drive strut are machined from tough 6000-series aluminum for maximum strength and then anodized vivid blue for that unmistakable Traxxas look. The drive strut uses special bushings for corrosion-free performance and features an oiling hole for easy maintenance.
Spartan uses corrosion-resistant stainless-steel and nickel-plated hardware throughout for good looks, easy maintenance, and long-lasting performance.
Spartan's dual trim tabs and turn fins are critical to its high-speed performance. The parts are precision die-cut and bent from stainless steel to resist corrosion as they provide aggressive cornering 'bite' and the proper hull attitude for water-boiling speed.
Spartan's water outlet is streamlined and integrated into the hull to maintain its sleek look. Even the smallest details are important when creating a 50+ mph speed machine.
Spartan comes outfitted from the factory with heavy duty, low-profile hatch nuts to keep the rigid ABS hatch securely fastened. Just a quick turn with the included hatch nut tool gives you full access to the hull. Spartan also includes a set of optional wingnuts for quick toolless installation and removal.
Spartan's bold graphics make a statement on the lake, with a custom look even pro painters can't match. No painting or decals are required; all the graphics are pre-applied to get Spartan out of the box and into the water with speed and style.
Spartan SR’s deep-V hull gets on plane quickly and efficiently for maximum acceleration and speed. The large 36? hull provides a commanding presence on the water and delivers excellent stability and responsiveness whether cutting through chop or skimming across glassy water.
A pickup in the aluminum rudder sends cooling water to the motor and ESC. A sealed motor jacket flows water directly around the aluminum can for maximum heat transfer. This efficient design helps Spartan keep its cool, run after run, for trouble-free all-day fun.
Spartan requires a powerful steering servo for responsive performance, and Traxxas delivers with the 2056 high-torque servo. O-ring seals make the servo completely waterproof, and there's plenty of steering muscle with 80 oz-in of torque at your command.
Spartan’s new heavy duty 4.7 mm flex shaft is 25% larger in diameter for the ultimate in power handling and reliability. Additionally, Spartan’s new electronics tray maximizes efficiency by moving the motor further back for a shorter and more direct path to the prop.
Spartan SR’s clamping collet holds the flex cable tightly and centers it perfectly with the motor's output shaft for smooth, efficient operation. The collet releases quickly with a twist of the included wrench for easy maintenance. Once loosened, the prop and flex cable simply slide out, making it easy to keep your Spartan SR running in peak form.
The 1800 kV Velineon 540XL motor is optimized for maximum power and efficiency in marine applications with ultra high-temperature sintered neodymium magnets, a precision-balanced rotor, and high-speed ball bearings.
Traxxas' patented waterproof receiver box routes wires neatly through a special watertight seal. A blue O-ring allows easy access to the receiver box without losing its sealing properties.
Waterproof electronics are a must in a marine environment. Traxxas electronics are fully waterproof (not just water resistant). The speed control, servo, and receiver all feature rugged waterproofing protection for dependable operation you can count on.
Designed for 6s LiPo power, the VXL-6s Marine transforms 22+ volts into 50+ mph speed on the water. The VXL-6s Marine is fully waterproof with integrated water cooling in the case and thermal overload protection for reliable all-day performance.
If Spartan SR should land keel-up in the water, an inlet at the top of the hull begins filling the flood chamber with water. The weight of the water pulls the boat to one side until it rights itself. Apply throttle to evacuate the flood chamber and you’re back in the action. The whole process takes only seconds and requires no special technique or skill.
Spartan’s adjustable center battery tray holds a variety of different LiPo batteries. Convenient hook-and-loop straps and foam pads secure the batteries tightly to prevent load shift, even under the roughest conditions.
Spartan SR’s built-in foam flotation ensures the boat maintains proper buoyancy while self righting. In addition to making Spartan SR virtually unsinkable, the fitted foam insert adds extra rigidity to the bow.
