Assembled Center Differential
Differential kit, center (complete) (requires #10757 center driveshaft & #10762 pinion gear)
Note: When installing the center differential, you must replace the standard driveshaft with a shorter 10757-series driveshaft and add the 10762 differential pinion gear.
