Assembled Heavy-Duty Metal Center Differential
10760R
$69.95
Differential kit, center (complete with steel spur gear) (aluminum carrier) (requires #10757 center driveshaft & 10762 pinion gear)
Note: When installing the center differential, you must replace the standard driveshaft with a shorter 10757-series driveshaft and add the 10762 differential pinion gear.
