Currency
US Dollar (USD)
Model Name:
Bandit VXL w/TSM
Model Type:
Buggy
Model Speed:
70+ mph with 3s LiPo battery and optional 33-tooth pinion gear (sold separately)
Model Skill Level:
2
1/10
3 pounds (1.36 kg)
16.25 inches (413 mm)
9.84 inches (250 mm)
Front Track:
Rear Track:
7 inches (178 mm)
11.25 inches (286 mm)
Drivetrain:
2WD
Transmission:
Magnum 272™
Planetary steel gear
Gear Ratio (Internal):
2.72 (final drive: 7.97)
48 pitch
Servo(s):
TQi™ 2.4 GHz 2-channel transmitter with 6533 receiver
Battery Compartment Specs:
166 mm X 47.5 mm X 28 mm
Motor Name:
Velineon® 3500
Motor Type:
Sensorless brushless
Motor Weight:
9.24 ounces (262 g)
Motor Length:
Motor Diameter:
1.41 inches (36 mm)
Motor Shaft Size:
3 mm
Motor Connector Type:
3.5 mm bullet
ESC Name:
ESC Type:
Brushless
ESC Case Size:
ESC Weight:
3.17 ounces (90 g)
Motor Connectors:
3.5 mm bullet
Battery Connectors:
ESC Power Wire:
12 gauge Maxx® Cable
ProGraphix® Painted Body ProGraphix® Painted Body Pre-painted body with applied decals Pre-painted body with applied decals Pre-painted body with applied decals Pre-painted body with applied decals Aggressive, aerodynamic body with rear wing Aggressive, aerodynamic body with rear wing Aggressive, aerodynamic body with rear wing Aggressive, aerodynamic body with rear wing VXL-3s™ Waterproof Electronic Speed Control VXL-3s™ Waterproof Electronic Speed Control Traxxas EZ-Set® one-button setup Traxxas EZ-Set® one-button setup Sport Mode - Forward / Brake / Reverse Traxxas EZ-Set® one-button setup Sport Mode - Forward / Brake / Reverse Sport Mode - Forward / Brake / Reverse Sport Mode - Forward / Brake / Reverse Traxxas EZ-Set® one-button setup Large heat sink Race Mode - Forward / Brake Race Mode - Forward / Brake Large heat sink Race Mode - Forward / Brake Large heat sink Race Mode - Forward / Brake Large heat sink Training Mode™ - 50% Forward / Brake / 50% Reverse (patented) Built-in two-stage low-voltage detection for LiPo batteries Training Mode™ - 50% Forward / Brake / 50% Reverse (patented) Built-in two-stage low-voltage detection for LiPo batteries Built-in two-stage low-voltage detection for LiPo batteries Built-in two-stage low-voltage detection for LiPo batteries Training Mode™ - 50% Forward / Brake / 50% Reverse (patented) Training Mode™ - 50% Forward / Brake / 50% Reverse (patented) NiMH battery packs: 4-9 cells (4.8 to 10.8 volts) NiMH battery packs: 4-9 cells (4.8 to 10.8 volts) NiMH battery packs: 4-9 cells (4.8 to 10.8 volts) NiMH battery packs: 4-9 cells (4.8 to 10.8 volts) LiPo battery packs: 2-3 cells (7.4 to 11.1 volts) LiPo battery packs: 2-3 cells (7.4 to 11.1 volts) LiPo battery packs: 2-3 cells (7.4 to 11.1 volts) LiPo battery packs: 2-3 cells (7.4 to 11.1 volts) Velineon® 3500 kV Brushless Motor Velineon® 3500 kV Brushless Motor Ultra high-temperature sintered Neodymium magnets Ultra high-temperature sintered Neodymium magnets Ultra high-temperature sintered Neodymium magnets Ultra high-temperature sintered Neodymium magnets Optimized for power and efficiency in 1/10th scale vehicles Optimized for power and efficiency in 1/10th scale vehicles Optimized for power and efficiency in 1/10th scale vehicles Optimized for power and efficiency in 1/10th scale vehicles Low-maintenance, unique Traxxas design Low-maintenance, unique Traxxas design Low-maintenance, unique Traxxas design Low-maintenance, unique Traxxas design Efficient, high-speed ball bearings Efficient, high-speed ball bearings Efficient, high-speed ball bearings Efficient, high-speed ball bearings Precision-balanced rotor Precision-balanced rotor Precision-balanced rotor Precision-balanced rotor 3500 kV 3500 kV 3500 kV 3500 kV Brilliant blue-anodized finish Brilliant blue-anodized finish Brilliant blue-anodized finish Brilliant blue-anodized finish Traxxas Stability Management® (TSM) Traxxas Stability Management® (TSM) Improves straight line acceleration and braking on low-traction surfaces Improves straight line acceleration and braking on low-traction surfaces Improves straight line acceleration and braking on low-traction surfaces Improves straight line acceleration and braking on low-traction surfaces Maintains steering composure to allow throttle-on powerslides Maintains steering composure to allow throttle-on powerslides Maintains steering composure to allow throttle-on powerslides Maintains steering composure to allow throttle-on powerslides Never dulls throttle or slows the vehicle Never dulls throttle or slows the vehicle Never dulls throttle or slows the vehicle Never dulls throttle or slows the vehicle Adjusts from off to 100% assistance from the transmitter Adjusts from off to 100% assistance from the transmitter Adjusts from off to 100% assistance from the transmitter Adjusts from off to 100% assistance from the transmitter TQi™ 2.4 GHz High Output Radio System TQi™ 2.4 GHz High Output Radio System TQi 2-channel transmitter TQi 2-channel transmitter TQi 2-channel transmitter TQi 2-channel transmitter 5-channel micro receiver (6533) with fail-safe security and integrated telemetry ports 5-channel micro receiver (6533) with fail-safe security and integrated telemetry ports 5-channel micro receiver (6533) with fail-safe security and integrated telemetry ports 5-channel micro receiver (6533) with fail-safe security and integrated telemetry ports Compatible with optional TQi Traxxas Link Wireless Module (6511) to access full Traxxas Link app functionality (sold separately) Compatible with optional TQi Traxxas Link Wireless Module (6511) to access full Traxxas Link app functionality (sold separately) Compatible with optional TQi Traxxas Link Wireless Module (6511) to access full Traxxas Link app functionality (sold separately) Compatible with optional TQi Traxxas Link Wireless Module (6511) to access full Traxxas Link app functionality (sold separately) Automatically stores and loads settings for up to 30 Traxxas Link-enabled models Automatically stores and loads settings for up to 30 Traxxas Link-enabled models Automatically stores and loads settings for up to 30 Traxxas Link-enabled models Automatically stores and loads settings for up to 30 Traxxas Link-enabled models Programmable multi-function knob Programmable multi-function knob Programmable multi-function knob Programmable multi-function knob Adjustable steering and throttle percentage (dual rates) Adjustable steering and throttle percentage (dual rates) Adjustable steering and throttle percentage (dual rates) Adjustable steering and throttle percentage (dual rates) Adjustable steering and throttle sensitivity (exponential) Adjustable steering and throttle sensitivity (exponential) Adjustable steering and throttle sensitivity (exponential) Adjustable steering and throttle sensitivity (exponential) Adjustable steering and throttle end points Adjustable steering and throttle end points Adjustable steering and throttle end points Adjustable steering and throttle end points Patented waterproof receiver box Patented waterproof receiver box Patented waterproof receiver box Patented waterproof receiver box Tough Fiber-Composite Monocoque Chassis Tough Fiber-Composite Monocoque Chassis Wide, low-profile design for increased stability Wide, low-profile design for increased stability Wide, low-profile design for increased stability Wide, low-profile design for increased stability All electronics securely fastened to chassis All electronics securely fastened to chassis All electronics securely fastened to chassis All electronics securely fastened to chassis Easy Access Battery Compartment Easy Access Battery Compartment Accepts 6-cell flat packs and 7-cell hump packs Accepts 6-cell flat packs and 7-cell hump packs Accepts 6-cell flat packs and 7-cell hump packs Accepts 6-cell flat packs and 7-cell hump packs Accepts short form factor 2-cell and 3-cell LiPo batteries Accepts short form factor 2-cell and 3-cell LiPo batteries Accepts short form factor 2-cell and 3-cell LiPo batteries Accepts short form factor 2-cell and 3-cell LiPo batteries Transmission and Driveline Transmission and Driveline Magnum 272™ metal-gear transmission Magnum 272™ metal-gear transmission Magnum 272™ metal-gear transmission Magnum 272™ metal-gear transmission Torque-Control™ slipper clutch system Torque-Control™ slipper clutch system Torque-Control™ slipper clutch system Torque-Control™ slipper clutch system Planetary gear differential with steel ring gear Planetary gear differential with steel ring gear Planetary gear differential with steel ring gear Planetary gear differential with steel ring gear Sealed gearbox protects the transmission with beefed up motor guard Sealed gearbox protects the transmission with beefed up motor guard Sealed gearbox protects the transmission with beefed up motor guard Sealed gearbox protects the transmission with beefed up motor guard External gear cover with easy clutch access External gear cover with easy clutch access External gear cover with easy clutch access External gear cover with easy clutch access Heavy-duty telescoping U-joint driveshafts and yokes Heavy-duty telescoping U-joint driveshafts and yokes Heavy-duty telescoping U-joint driveshafts and yokes Heavy-duty telescoping U-joint driveshafts and yokes Steering Steering Digital High-torque waterproof Traxxas 2075 steering servo Digital High-torque waterproof Traxxas 2075 steering servo Digital High-torque waterproof Traxxas 2075 steering servo Digital High-torque waterproof Traxxas 2075 steering servo High-performance bellcrank system minimizes bump steer High-performance bellcrank system minimizes bump steer High-performance bellcrank system minimizes bump steer High-performance bellcrank system minimizes bump steer Suspension Suspension Adjustable steel turnbuckles Adjustable steel turnbuckles Adjustable steel turnbuckles Adjustable steel turnbuckles Captured rod ends won't pop off Captured rod ends won't pop off Captured rod ends won't pop off Captured rod ends won't pop off Springs and Shocks Springs and Shocks Fully adjustable oil-filled Ultra Shocks™ with X-ring technology Fully adjustable oil-filled Ultra Shocks™ with X-ring technology Fully adjustable oil-filled Ultra Shocks™ with X-ring technology Fully adjustable oil-filled Ultra Shocks™ with X-ring technology White powder-coated springs White powder-coated springs White powder-coated springs White powder-coated springs Wheels and Tires Wheels and Tires Pre-glued Alias® step-pin rear tires and ribbed front tires with performance foam inserts Pre-glued Alias® step-pin rear tires and ribbed front tires with performance foam inserts Pre-glued Alias® step-pin rear tires and ribbed front tires with performance foam inserts Pre-glued Alias® step-pin rear tires and ribbed front tires with performance foam inserts 2.2″ Black-chrome 5-spoke Tracer™ wheels 2.2″ Black-chrome 5-spoke Tracer™ wheels 2.2″ Black-chrome 5-spoke Tracer™ wheels 2.2″ Black-chrome 5-spoke Tracer™ wheels Rubber-Sealed Ball Bearings Rubber-Sealed Ball Bearings Precision Hex Hardware Precision Hex Hardware Backed by Unparalleled Traxxas Support and Parts Availability Backed by Unparalleled Traxxas Support and Parts Availability Requires Battery and Charger (Sold Separately) Requires Battery and Charger (Sold Separately)
