Currency
US Dollar (USD)
Model Name:
Stampede VXL W/ MAGNUM 272R
Model Type:
Monster Truck
Model Speed:
65+ mph with 3s LiPo battery and optional 30-tooth pinion gear (sold separately)
Model Skill Level:
2
1/10
4.08 pounds (1.85 kg)
16.25 inches (413 mm)
12.75 inches (324 mm)
Front Track:
Rear Track:
9.5 inches (241 mm)
10.63 inches (270 mm)
Center Ground Clearance:
4 inches (102 mm)
Drivetrain:
2WD
Transmission:
Magnum 272™
Planetary steel gear
Gear Ratio (Internal):
2.72 (final drive: 12.34)
48 pitch
Servo(s):
Battery Compartment Specs:
164 mm X 46 mm X 26 mm
Motor Name:
Velineon® 3500
Motor Type:
Sensorless brushless
Motor Weight:
9.24 ounces (262 g)
Motor Length:
Motor Diameter:
1.41 inches (36 mm)
Motor Shaft Size:
3 mm
Motor Connector Type:
3.5 mm bullet
ESC Name:
ESC Type:
Brushless
ESC Case Size:
ESC Weight:
3.17 ounces (90 g)
Motor Connectors:
3.5 mm bullet
Battery Connectors:
ESC Power Wire:
12 gauge Maxx® Cable
ProGraphix® Painted Body Pre-painted monster truck body with applied decals VXL-3s™ Waterproof Electronic Speed Control Traxxas EZ-Set® one-button setup Sport Mode - Forward / Brake / Reverse Large heat sink Race Mode - Forward / Brake Built-in two-stage low-voltage detection for LiPo batteries Training Mode™ - 50% Forward / Brake / 50% Reverse (patented) NiMH battery packs: 4-9 cells (4.8 to 10.8 volts) LiPo battery packs: 2-3 cells (7.4 to 11.1 volts) Velineon® 3500 kV Brushless Motor Ultra high-temperature sintered Neodymium magnets Optimized for power and efficiency in 1/10th scale vehicles Low-maintenance, unique Traxxas design Efficient, high-speed ball bearings Precision-balanced rotor 3500 kV Brilliant blue-anodized finish Traxxas Stability Management® (TSM) Improves straight line acceleration and braking on low-traction surfaces Maintains steering composure to allow throttle-on powerslides Never dulls throttle or slows the vehicle Adjusts from off to 100% assistance from the transmitter TQi™ 2.4 GHz High Output Radio System TQi 2-channel transmitter 5-channel micro receiver (6533) with fail-safe security and integrated telemetry ports Compatible with optional TQi Traxxas Link Wireless Module (6511) to access full Traxxas Link app functionality (sold separately) Automatically stores and loads settings for up to 30 Traxxas Link-enabled models Programmable multi-function knob Adjustable steering and throttle percentage (dual rates) Adjustable steering and throttle sensitivity (exponential) Adjustable steering and throttle end points Patented waterproof receiver box Tough Fiber-Composite Monocoque Chassis Tall 4″ center ground clearance to drive over obstacles All electronics securely fastened to chassis Includes adjustable wheelie bar Easy Access Battery Compartment Accepts 6-cell flat packs and 7-cell hump packs Accepts short form factor 2-cell and 3-cell LiPo batteries Transmission and Driveline Magnum 272™ metal-gear transmission Torque-Control™ slipper clutch system Planetary gear differential with steel ring gear Sealed gearbox protects the transmission with beefed up motor guard External gear cover with easy clutch access Heavy-duty telescoping U-joint driveshafts and yokes Steering Digital High-torque waterproof Traxxas 2075 steering servo Spring-loaded servo saver helps protect against impacts Suspension Adjustable steel turnbuckles Captured rod ends won't pop off Springs and Shocks Fully adjustable oil-filled Ultra Shocks™ with X-ring technology White powder-coated springs Wheels and Tires Pre-glued high profile Talon™ all-terrain tires with performance foam inserts 2.8″ Mirror-chrome All-Star™ wheels Rubber-Sealed Ball Bearings Precision Hex Hardware Backed by Unparalleled Traxxas Support and Parts Availability Requires Battery and Charger (Sold Separately)
