Currency
US Dollar (USD)
Battery & Charger
Included
Rustler 2WD XL-5 w/Battery
Model Name:
Rustler 2WD HD w/USB-C
Model Type:
Stadium Trucks
Model Speed:
35+ mph with 7-cell battery
Model Skill Level:
1
1/10
3.73 pounds (1.69 kg)
17.5 inches (445 mm)
12.25 inches (311 mm)
Front Track:
Rear Track:
7 inches (178 mm)
11.38 inches (289 mm)
Drivetrain:
2WD
Transmission:
Magnum 272™
Planetary steel gear
Gear Ratio (Internal):
2.72 (final drive: 10.17)
48 pitch
Servo(s):
2056 high torque waterproof
TQ™ 2.4 GHz 2-channel radio
Battery Compartment Specs:
166 mm X 47.5 mm X 28 mm
Motor Name:
Titan® 12T 550
Motor Type:
High-speed brushed motor
Motor Weight:
8.47 ounces (240 g)
Motor Length:
Motor Diameter:
1.41 inches (36 mm)
Motor Shaft Size:
3 mm
Motor Connector Type:
Bullet
ESC Name:
Waterproof XL-5 ESC with low-voltage detection
ESC Type:
Brushed
ESC Case Size:
1.23 inches (31 mm) / 2.18 inches (55 mm) / 0.61 inches (15 mm)
ESC Weight:
2.44 ounces (69 g)
Motor Connectors:
Bullet
Battery Connectors:
ESC Power Wire:
14 gauge
Clipless Stadium Truck Body Pre-painted body with applied decals Aggressive, aerodynamic body with rear wing Body reinforcements to prevent pull-through damage Holds tight for intense action Quick and easy removal Smooth appearance with no body posts or clips High-Performance Waterproof XL-5™ Electronic Speed Control Innovative waterproof design Three drive profiles Sport Mode - forward / brake / reverse Race Mode - forward / brake Training Mode™ - 50% forward / brake / 50% reverse (patented) Traxxas EZ-Set® one-button setup LiPo and NiMH compatible with two-stage low-voltage detection Titan 550 Motor Powerful Titan® 12T 550 brushed motor with internal cooling fan Oversized armature for big torque and increased power handling Virtually maintenance-free operation Extreme Heavy Duty Parts Installed Strengthened C-hubs, axle carriers, and steering blocks HD suspension arms TQ™ 2.4 GHz 2-Channel Radio System Ergonomic transmitter with internal antenna Traxxas 6519 3-channel micro receiver with fail-safe security Sealed watertight receiver box keeps the receiver dry Includes Battery and USB-C Charger 4-amp USB-C fast charger 3000 mAh Traxxas 7-cell 8.4 V NiMH battery with iD® Easy Access Battery Compartment Accepts NiMH 6 and 7-cell flat packs and hump packs Accepts 2-cell LiPo batteries Transmission and Driveline Brushless-ready Magnum 272™ metal-gear transmission Torque-Control™ slipper clutch system Planetary gear differential with steel ring gear Sealed gearbox protects the transmission with beefed up motor guard External gear cover with easy clutch access Heavy-duty telescoping U-joint driveshafts and yokes Tough Fiber-Composite Monocoque Chassis Wide, low-profile design for increased stability Steering High-torque waterproof Traxxas 2056 steering servo Spring-loaded servo saver helps protect against impacts Suspension Durable solid camber links eliminate the need for adjustment Captured rod ends won't pop off Springs and Shocks Fully adjustable oil-filled Ultra Shocks™ with X-ring technology White powder-coated springs Wheels and Tires Pre-glued Alias® step-pin rear tires and ribbed front tires with performance foam inserts 2.8″ black six-spoke wheels with chrome beadlock trim Precision Hex Hardware
