Currency
US Dollar (USD)
Battery & Charger
Sold Separately
Rustler 2WD BL-2s
Model Name:
Rustler 2WD BL-2s HD
Model Type:
Stadium Trucks
Model Speed:
35+ mph with 7-cell battery
Model Skill Level:
1
1/10
3.73 pounds (1.69 kg)
17.5 inches (445 mm)
12.25 inches (311 mm)
Front Track:
Rear Track:
7 inches (178 mm)
11.38 inches (289 mm)
Drivetrain:
2WD
Transmission:
Magnum 272™
Planetary steel gear
Gear Ratio (Internal):
2.72 (final drive: 10.17)
48 pitch
Servo(s):
2056 high torque waterproof
TQ™ 2.4 GHz 2-channel radio
Battery Compartment Specs:
166 mm X 47.5 mm X 28 mm
Motor Name:
BL-2s 3300 kV
Motor Type:
Sensorless brushless
Motor Weight:
7.51 ounces (213 g)
Motor Length:
3.15 inches (80 mm)
Motor Diameter:
1.42 inches (36 mm)
Motor Shaft Size:
3 mm
Motor Connector Type:
Traxxas Quick Connect Motor Plug
ESC Name:
BL-2s Electronic Speed Control
ESC Type:
Brushless
ESC Case Size:
1.53″ (39 mm) x 2.31″ (59 mm) x 1.21″ (31 mm)
ESC Weight:
3.07 ounces (87 g)
Motor Connectors:
Battery Connectors:
Clipless Stadium Truck Body Tough LED-ready front and rear bumpers Includes wheelie bar Aerodynamic body with rear wing Body reinforcements to prevent pull-through damage Holds tight for intense action Quick and easy removal Smooth appearance with no body posts or clips BL-2s™ Waterproof Electronic Speed Control Heat sink accepts accessory cooling fan Three Programmable Drive Profiles Sport Mode - forward / brake / reverse Race Mode - forward / brake Training Mode™ - 50% forward / brake / 50% reverse (patented) Traxxas EZ-Set® one-button setup LiPo and NiMH compatible with two-stage low-voltage detection NiMH battery packs: 6-7 cells (7.2 to 8.4 volts) LiPo battery packs: 2 cells (7.4 volts) BL-2s Brushless Motor Integrated cooling fan Low-maintenance design Efficient ball bearings 3300 kV Virtually maintenance-free Extreme Heavy Duty Parts Installed Strengthened C-hubs, axle carriers, and steering blocks HD suspension arms Extreme heavy duty driveshafts Extra material for improved strength TQ™ 2.4 GHz 2-Channel Radio System Ergonomic transmitter with internal antenna Traxxas 6519 3-channel micro receiver with fail-safe security O-ring sealed watertight receiver box keeps the receiver dry Easy Access Battery Compartment Adjustable battery hold down Accepts 6- and 7-cell flat packs and 7-cell hump packs Accepts many 2s LiPo battery configurations Transmission and Driveline Velineon® -ready Magnum 272™ metal-gear transmission Torque-Control™ slipper clutch system Planetary gear differential with steel ring gear Sealed gearbox protects the transmission with beefed up motor guard External gear cover with easy clutch access Tough Fiber-Composite Monocoque Chassis Wide, low-profile design for increased stability Steering High-torque waterproof Traxxas 2056 steering servo Spring-loaded servo saver helps protect against impacts Suspension Durable solid camber links eliminate the need for adjustment Captured rod ends won't pop off Springs and Shocks Fully adjustable oil-filled Ultra Shocks™ with X-ring technology White powder-coated springs Wheels and Tires Pre-glued Alias® step-pin rear tires and ribbed front tires with performance foam inserts 2.8″ All-Star™ wheels Rubber-Sealed Ball Bearings Precision Hex Hardware Battery and Charger Sold Separately
