Currency
US Dollar (USD)
Slash VXL 2WD Brless OBA & TSM
Model Name:
Slash VXL TSM
Model Type:
Short Course Trucks
Model Speed:
60+ mph with 3S LiPo and Pinion/Spur 31/76
Model Skill Level:
1
1/10
5.64 pounds (2.56 kg)
22.36 inches (568 mm)
11.65 inches (296 mm)
Front Track:
Rear Track:
8.43 inches (214 mm)
13.2 inches (335 mm)
Transmission:
Metal Gear Magnum 272™
Planetary Steel Gear
Gear Ratio (Internal):
2.72 (Final Drive: 10.2)
48 Pitch
Servo(s):
Digital High-Torque Waterproof #2075
TQi™ 2.4 GHz 3-Channel Transmitter with #6533 Receiver
Battery Compartment Specs:
165 mm X 49.5 mm X 23 mm, 25 mm
Motor Name:
Velineon® 3500
Motor Type:
Sensorless brushless
Motor Weight:
9.24 ounces (262 g)
Motor Length:
Motor Diameter:
1.41 inches (36 mm)
Motor Shaft Size:
3 mm
ESC Name:
VXL-3s™ Electronic Speed Control
ESC Case Size:
ESC Weight:
3.17 ounces (90 g)
Battery Connectors:
ESC Power Wire:
12 gauge Maxx Cable
Race Replica ProGraphix® Painted Body Pre-painted body with applied decals Scale dimensions and looks of actual short course race trucks Chassis nerf bars absorb impact and support the body Scale front and rear tube-style bumpers Traxxas On-Board Audio Uses actual engine sounds sampled from a Pro 4X4 short course truck Volume can be turned down or off Completely waterproof VXL-3s™ Waterproof Electronic Speed Control Sport Mode - Forward / Brake / Reverse Traxxas EZ-Set® one-button setup Large heat sink Race Mode - Forward / Brake Training Mode™ - 50% Forward / Brake / 50% Reverse (patented) Built-in two-stage low-voltage detection for LiPo batteries NiMH battery packs: 4-9 cells (4.8 to 10.8 volts) LiPo battery packs: 2-3 cells (7.4 to 11.1 volts) Velineon® �Brushless Motor Ultra high-temperature sintered Neodymium magnets Optimized for power and efficiency in 1/10th scale vehicles Low-maintenance, unique Traxxas design Efficient, high-speed ball bearings Precision-balanced rotor 3500kV Brilliant blue-anodized finish Traxxas Stability Management® (TSM) Improves straight line acceleration and braking on low-traction surfaces Maintains steering composure to allow throttle-on powerslides Never dulls throttle or slows the truck Adjusts from off to 100% assistance from the transmitter TQi™ 2.4GHz High Output Radio System TQi 3-channel transmitter Patented waterproof receiver box Rocker switch on the transmitter to engage “Neutral” mode 5-channel micro receiver (#6533) with fail-safe security and integrated telemetry ports Compatible with optional TQi Traxxas Link Wireless Module (#6511) to access full Traxxas Link app functionality (sold separately) Automatically stores and loads settings for up to 30 Traxxas Link-enabled models Programmable multi-function knob Adjustable steering and throttle percentage (dual rates) Adjustable steering and throttle sensitivity (exponential) Adjustable steering and throttle end points Low-CG Reinforced Monocoque Chassis Batteries and electronics held low for improved handling Long 13.2” wheelbase for increased stability Low-CG design dramatically increases corner speed All electronics securely fastened to chassis Easy Access Battery Compartment Adjustable battery hold down Accepts 6- and 7-cell NiMH flat packs Accepts many 2S and 3S LiPo battery configurations Transmission and Driveline Magnum 272™ metal-gear transmission Torque-Control™ slipper clutch system Planetary gear differential with steel ring gear Sealed gearbox protects the transmission with beefed up motor guard External gear cover with easy clutch access Heavy-duty telescoping U-joint driveshafts and yokes Steering Digital High-torque waterproof Traxxas #2075 steering servo Dual-bellcrank steering with integrated servo saver Suspension Adjustable steel turnbuckles Captured rod ends won't pop off Springs and Shocks Fully adjustable oil-filled Ultra Shocks™ with X-ring technology Race-tuned progressive rate white powder-coated springs Wheels and Tires Pre-glued scale all-terrain tires with performance foam inserts 2” outer diameter, 3” inner diameter dual-profile SCT wheels Rubber-Sealed Ball Bearings Precision Hex Hardware Backed by Unparalleled Traxxas Support and Parts Availability Requires Battery and Charger (Sold Separately)
