Please create a new account
Sign Up Here
Learn more.
Learn more.
WARNING: This product can expose you to chemicals including Nitromethane, which is known to the State of California to cause cancer, and Methanol, which is known by the State of California to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov.
Gallery
Specs
Features
Parts Finder
Exploded Views
Support
Model Name:
Slayer Pro 4X4
Model Type:
Short Course Trucks
Model Speed:
50+ mph with optional 17-tooth clutch bell (5217), sold separately. 45+ mph stock
Model Skill Level:
4
1/10
7.78 pounds (3.53 kg)
23.54 inches (598 mm)
12.68 Inches (322 mm)
Front Track:
Rear Track:
7.87 inches (200 mm)
13.9 Inches (353 mm)
Center Ground Clearance:
2.5 Inches (63.5 mm)
Drivetrain:
Shaft-driven 4WD
Transmission:
Auto two-speed forward only
Bevel gear, sealed, limited slip
Gear Ratio (Internal):
15.75:1 (1st gear) 10.05:1 (2nd gear)
1.0 metric pitch (Mod 1)
Servo(s):
2075 dual digital high-torque waterproof
Starter:
Electric EZ-Start®
Carburetor:
Two-needle slide carburetor
Air Filter:
Dual-stage foam
150 cc
ProGraphix® Painted Body
Pre-painted body with applied decals
Scale dimensions and looks of actual short course race trucks
Chassis nerf bars absorb impact and support the body
Scale front and rear tube-style bumpers
TRX® 3.3 Racing Engine
Large bore piston and sleeve deliver extreme power
High-volume dual-stage air filter
Tuned polished aluminum Resonator™ exhaust pipe
Slide carburetor
Knife-edged connecting rod
Large aluminum blue-anodized cooling head
Super-light piston and rod
High-performance ball bearings
Maintains steering composure to allow throttle-on powerslides
Never dulls throttle or slows the vehicle
2-channel high output transmitter
Automatically stores and loads settings for up to 30 Traxxas Link-enabled models—just switch on and drive, "model selection" is not required
Multi-Function knob
Compact receiver and battery box with integrated personal transponder mount
EZ-Start® Electric Starting System
Lights the glow plug and cranks the engine with the push of a button
Status LEDs
Includes starter battery and charger
Blue-Anodized Aluminum Chassis
Blue-anodized 3 mm aluminum 3D semi-monocoque chassis
Long wheelbase chassis and wide track suspension arms
Waterproof steering and throttle/brake servos
Large 150 cc fuel tank extends run time
Transmission and Driveline
Two-speed forward only transmission with adjustable shift point
Ultra-compact with fewer moving parts
Low rotating mass for quick, high-revving acceleration
Constant drive engagement is smooth and instantly responsive
Sealed case protects gears & two-speed from damaging debris
Tunable front and rear sealed, limited-slip gear differentials
