Currency
US Dollar (USD)
Battery & Charger
Included
1/18 LaTrax Teton
Model Name:
LaTrax 1/18 Teton
Model Type:
Monster Truck
Model Skill Level:
1
1/18
15.2 ounces (430 g)
10.16 inches (258 mm)
Front Track:
4.17 inches (106 mm)
Rear Track:
4.23 inches (108 mm)
4.65 inches (118 mm)
6.44 inches (164 mm)
Center Ground Clearance:
1.18 inches (30 mm)
Drivetrain:
Shaft-driven 4WD
Transmission:
10-T pinion / 60-T spur
Hardened steel bevel (ring and pinion)
Gear Ratio (Internal):
2.5:1
0.5 module
Servo(s):
2065 waterproof
2.4 GHz 2-channel radio
Battery Compartment Specs:
102 mm X 35 mm X 18 mm
ESC Name:
Waterproof forward/reverse ESC
ESC Type:
Brushed
Tough Monster Truck Body 1/18 Scale pre-painted body with applied decals Adjustable-height body mounts Waterproof Electronic Speed Control Innovative waterproof design Fully-proportional forward, reverse, and braking control Three drive profiles Sport Mode - forward / brake / reverse Race Mode - forward / brake Training Mode™ - 50% forward / brake / 50% reverse (patented) EZ-Set® one-button setup Thermal shutdown protection Motor Powerful 370 brushed motor Virtually maintenance-free operation 2.4 GHz 2-Channel Radio System Ergonomic transmitter with internal antenna 3-channel micro receiver with fail-safe security Servo reversing Electronic steering trim controls Includes Battery and Charger AC wall-outlet charger 1200 mAh 6-cell 7.2 V NiMH battery with iD® Fiber-Composite Chassis Impact-absorbing front and rear bumpers Quick-release battery hold-down for fast battery changes Transmission and Driveline Full-time shaft-driven 4WD Metal-gear front and rear differentials Steering Waterproof sub-micro steering servo Integrated servo saver Suspension 4-wheel fully independent suspension Springs and Shocks Oil-filled coil-over shocks with variable mounting positions Wheels and Tires Aggressive off-road tires pre-glued to 5-spoke wheels Backed by Unparalleled Traxxas Support and Parts Availability
