X-Series Overdrive Gear Set
Gear set, overdrive (includes 47T ouput gear, 24T input gear, 3x10mm FCS (with threadlock) (4))
CAUTION!
This gear set is intended for advanced drivers only with previous experience and knowledge of large radio controlled vehicles capable of high speed and acceleration. This gear set is not intended for use on a stock vehicle without making the proper adjustments to the motor pinion, spur gear, tire size, and/or power system.
