Currency
US Dollar (USD)
Model Name:
TRX-4 Sport Kit
Model Type:
Trail / Crawler
Model Skill Level:
2
1/10
5.79 pounds (2.63 kg) (with electronics installed)
21.93 inches (557 mm)
9.78 inches (249 mm)
Front Track:
Rear Track:
9.47 inches (241 mm)
12.28 inches (312 mm)
Center Ground Clearance:
3.14 inches (80 mm)
Drivetrain:
Shaft-driven 4WD
Transmission:
Single speed
Spool (no differential)
32 pitch
Servo(s):
Sold separately
Sold separately
Battery Compartment Specs:
159 mm X 47 mm X 23 mm, 26 mm
Motor Name:
Sold separately
ESC Name:
Sold separately
Speed control, motor, servo, radio, battery, and charger sold separately Speed control, motor, servo, radio, battery, and charger sold separately Easy to follow full-color assembly manual Easy to follow full-color assembly manual True-to-scale part illustrations and ruler charts True-to-scale part illustrations and ruler charts True-to-scale part illustrations and ruler charts True-to-scale part illustrations and ruler charts Helpful assembly tips and clear illustrations Helpful assembly tips and clear illustrations Helpful assembly tips and clear illustrations Helpful assembly tips and clear illustrations Clear TRX-4® �Sport body Clear TRX-4® �Sport body Body comes pre-cut and ready to mount Body comes pre-cut and ready to mount Body comes pre-cut and ready to mount Body comes pre-cut and ready to mount Includes window masking and decals Includes window masking and decals Includes window masking and decals Includes window masking and decals Includes Expedition Rack with scale accessories Includes Expedition Rack with scale accessories Includes Expedition Rack with scale accessories Includes Expedition Rack with scale accessories Front grille and rear tail gate with lenses for LED lights Front grille and rear tail gate with lenses for LED lights Front grille and rear tail gate with lenses for LED lights Front grille and rear tail gate with lenses for LED lights Rugged front and rear bumpers with red D-rings Rugged front and rear bumpers with red D-rings Rugged front and rear bumpers with red D-rings Rugged front and rear bumpers with red D-rings (Requires polycarbonate paint) (Requires polycarbonate paint) Portal Axles Portal Axles Increase ground clearance Increase ground clearance Increase ground clearance Increase ground clearance Eliminate torque twist Eliminate torque twist Eliminate torque twist Eliminate torque twist Steel gears Steel gears Steel gears Steel gears Improve axle geometry and reduce strain on driveshafts Improve axle geometry and reduce strain on driveshafts Improve axle geometry and reduce strain on driveshafts Improve axle geometry and reduce strain on driveshafts Rigid Steel Frame Rigid Steel Frame 1.5 mm thick steel frame rails increase torsional rigidity 1.5 mm thick steel frame rails increase torsional rigidity 1.5 mm thick steel frame rails increase torsional rigidity 1.5 mm thick steel frame rails increase torsional rigidity Innovative design allows four wheelbase positions (300 mm, 312 mm (standard), 324 mm, 336 mm) Innovative design allows four wheelbase positions (300 mm, 312 mm (standard), 324 mm, 336 mm) Innovative design allows four wheelbase positions (300 mm, 312 mm (standard), 324 mm, 336 mm) Innovative design allows four wheelbase positions (300 mm, 312 mm (standard), 324 mm, 336 mm) Adjustable rear shock tower positions Adjustable rear shock tower positions Adjustable rear shock tower positions Adjustable rear shock tower positions Bumpers adjust fore and aft Bumpers adjust fore and aft Bumpers adjust fore and aft Bumpers adjust fore and aft Rugged rock rails adjust for width Rugged rock rails adjust for width Rugged rock rails adjust for width Rugged rock rails adjust for width Wire routing clips integrated into frame rails Wire routing clips integrated into frame rails Wire routing clips integrated into frame rails Wire routing clips integrated into frame rails Innovative Battery Compartment Innovative Battery Compartment Hinged battery strap allows quick and easy battery access Hinged battery strap allows quick and easy battery access Hinged battery strap allows quick and easy battery access Hinged battery strap allows quick and easy battery access No pins to lose No pins to lose No pins to lose No pins to lose Accommodates different height batteries Accommodates different height batteries Accommodates different height batteries Accommodates different height batteries Accepts full-size long battery packs Accepts full-size long battery packs Accepts full-size long battery packs Accepts full-size long battery packs Integrated compartment accepts smaller 1/16 scale batteries (with optional strap) Integrated compartment accepts smaller 1/16 scale batteries (with optional strap) Integrated compartment accepts smaller 1/16 scale batteries (with optional strap) Integrated compartment accepts smaller 1/16 scale batteries (with optional strap) Transmission Transmission Single-speed with steel gears Single-speed with steel gears Single-speed with steel gears Single-speed with steel gears Twin friction plate slipper clutch Twin friction plate slipper clutch Twin friction plate slipper clutch Twin friction plate slipper clutch Easily removed for servicing Easily removed for servicing Easily removed for servicing Easily removed for servicing Drivetrain Drivetrain Full-time shaft driven 4-wheel drive Full-time shaft driven 4-wheel drive Full-time shaft driven 4-wheel drive Full-time shaft driven 4-wheel drive Tough 6 mm stub axles Tough 6 mm stub axles Tough 6 mm stub axles Tough 6 mm stub axles Steel front CV driveshafts Steel front CV driveshafts Steel front CV driveshafts Steel front CV driveshafts Hardened steel rear axle shafts Hardened steel rear axle shafts Hardened steel rear axle shafts Hardened steel rear axle shafts Steel gear transfer case Steel gear transfer case Steel gear transfer case Steel gear transfer case Steering Steering Accepts standard size servos Accepts standard size servos Accepts standard size servos Accepts standard size servos Superior 45° steering angle Superior 45° steering angle Superior 45° steering angle Superior 45° steering angle Direct steering (no servo saver) Direct steering (no servo saver) Direct steering (no servo saver) Direct steering (no servo saver) Steering geometry corrected for bump steer Steering geometry corrected for bump steer Steering geometry corrected for bump steer Steering geometry corrected for bump steer Suspension Suspension Front — 3 link with panhard Front — 3 link with panhard Front — 3 link with panhard Front — 3 link with panhard Rear — Dual triangulated 4 link Rear — Dual triangulated 4 link Rear — Dual triangulated 4 link Rear — Dual triangulated 4 link Heavy-duty rod ends with steel hollow balls Heavy-duty rod ends with steel hollow balls Heavy-duty rod ends with steel hollow balls Heavy-duty rod ends with steel hollow balls 5 mm diameter lower steel link rods with 4 mm threaded ends 5 mm diameter lower steel link rods with 4 mm threaded ends 5 mm diameter lower steel link rods with 4 mm threaded ends 5 mm diameter lower steel link rods with 4 mm threaded ends Pre-assembled aluminum GTS Shocks Pre-assembled aluminum GTS Shocks Oil-filled coilover GTS shocks Oil-filled coilover GTS shocks Oil-filled coilover GTS shocks Oil-filled coilover GTS shocks Silver-anodized aluminum bodies Silver-anodized aluminum bodies Silver-anodized aluminum bodies Silver-anodized aluminum bodies Threaded bodies with collars easily adjust ride height Threaded bodies with collars easily adjust ride height Threaded bodies with collars easily adjust ride height Threaded bodies with collars easily adjust ride height Silky smooth damping for the toughest trails Silky smooth damping for the toughest trails Silky smooth damping for the toughest trails Silky smooth damping for the toughest trails O-ring�cap seal and dual�X-ring�shaft seals O-ring�cap seal and dual�X-ring�shaft seals O-ring�cap seal and dual�X-ring�shaft seals O-ring�cap seal and dual�X-ring�shaft seals Shock oil included in kit Shock oil included in kit Shock oil included in kit Shock oil included in kit Wheels and Tires Wheels and Tires 1.9” Canyon Trail tires with trail-tuned foam inserts 1.9” Canyon Trail tires with trail-tuned foam inserts 1.9” Canyon Trail tires with trail-tuned foam inserts 1.9” Canyon Trail tires with trail-tuned foam inserts Tough black scale wheels Tough black scale wheels Tough black scale wheels Tough black scale wheels Trail tuned S1 rubber compound Trail tuned S1 rubber compound Trail tuned S1 rubber compound Trail tuned S1 rubber compound 12 mm steel hex 12 mm steel hex 12 mm steel hex 12 mm steel hex Tire glue required Tire glue required Tire glue required Tire glue required Sealed ball bearings Sealed ball bearings Hex hardware with rust-resistant black oxide coating Hex hardware with rust-resistant black oxide coating Patented O-ring sealed watertight receiver box keeps the micro receiver dry Patented O-ring sealed watertight receiver box keeps the micro receiver dry
