Please create a new account
Sign Up Here
Learn more.
Learn more.
Originally introduced in 1966 as a 4X4 compact SUV, the Ford® Bronco matured as a full-size truck in the late 1970s, cementing its status as a rugged off-roader. Traxxas honors the classic 1979 Ford Bronco with this beautifully detailed and faithful reproduction mounted on the incredibly capable TRX-4® chassis. From the chrome wheels and bumpers to the gorgeous Sunset or red graphics, the TRX-4 recaptures the Bronco’s iconic era with the toughness and technology that could only come from Traxxas.
Video
Innovation
The Power of Portals
Portal axles lift the truck at the wheels for huge center pumpkin ground clearance. In order to achieve the same clearance with straight axles, your tires would have to be over an inch taller than the tires on TRX-4 Bronco.
Torque Twist Eliminated
Portal axles use gear reduction at the wheels to virtually eliminate torque twist. The Titan 550 motor’s torque translates into straight, powerful, forward motion, rather than wasted energy twisting your rig right off the rocks.
New Chassis Design
TRX-4 Bronco instantly obsoletes the status quo with greatly expanded features, versatility, and capability. Performance and technology combine in a revolutionary chassis that looks as good as it performs.
Rigid Steel Frame
A heavy-duty formed-steel ladder frame with molded cross members creates an extremely rigid backbone. You’ll feel the difference on trails when navigating technical terrain.
Scale Details
Oil-filled coil-over GTS shocks deliver silky-smooth damping performance and feature threaded aluminum shock bodies for easy ride height adjustments. The convincing scale realism looks great and they perform even better.
Remote Locking Differentials
Traxxas allows you to lock and unlock both the front and rear differentials remotely from your transmitter. New sleeved micro cables control the differential action for scale appearance, without limiting suspension articulation.
i™ Radio System with Cruise Control" title="TQi™ Radio System with Cruise Control" />
GTS Aluminum Shocks
High/Low Range Transmission
When the going gets tough, shift into low range for incredible 4WD pulling torque. Shift into high range for blasting down the trail. TRX-4 Bronco adapts to any situation or driving style.
3s Power System
The XL-5™ HV electronic speed control brings 3s LiPo capability for stronge efficient running. The powerful 21T Titan® motor provides torque to tackle the steepest climbs and all-out speed on flat terrain. This efficient system provides up to 2 hours of run time with a Traxxas 3s 5000 mAh LiPo battery pack!
The Traxxas TQi features our exclusive cruise control for long-distance treks. Set your speed using the transmitter and then use the multi-function knob to fine-tune it faster or slower to match precisely the pace of your caravan of trail explorers.
Waterproof Electronics
TRX-4 is fully waterproof, not “splash resistant.” There is a big difference. Traxxas’ patented innovation gives you the freedom to tackle creeks, snow, and mud without worrying about water in your electronics.
Chassis
Driveline
Geometry
Electronics
Scale Details
Heavy-Duty Steel Frame Rails
Adjustable Wheelbase
Molded Wire Retainers
Dual Battery Tray
Floor Pans
Aluminum Scale Shocks
Heavy-Duty Steel Links
Precision Hex Hardware
Portal Axles
T-Lock™ Remote Locking Differentials
High/Low Transmission
Hardened Steel U-Joints
Twin Friction Plate Slipper Clutch
Sealed Ball Bearings
Raised Center Driveshafts and Suspension Links
High Steering and Drag Links
45° Steering Angle
Extreme Approach Angles
High Ground Clearance
Front Motor Design
New XL-5 HV ESC
Titan 21T 550 Motor
Waterproof Metal Gear Servo
TQi™ 4-Channel Radio System
Waterproof Micro Servos with Sleeved Cables
Accessory LED Light Kit (sold separately)
Officially Licensed Replica Body
1.9? Scale Wheels and Tires
Molded Inner Fenders
Rock Sliders
Detailed Front Grille and Chrome-Finish Bumpers
Chrome-Finish Differential Covers
Molded Body Details
Accessory Push Bar and Spare Tire
Make sure you don’t miss any of the latest Traxxas TRX-4 1979 Ford Bronco news, accessories, and updates.
