Currency
US Dollar (USD)
Motor Name:
Titan® 12T 550
Motor Type:
High-speed brushed motor
Motor Weight:
8.47 ounces (240 g)
Motor Length:
Motor Diameter:
1.41 inches (36 mm)
Motor Shaft Size:
3 mm
Motor Connector Type:
Bullet
Officially Licensed Ford® GT Body Black chrome wheels with lug nut detail Replica brake discs with red calipers Injection molded inserts Adjustable Body Mounts Fore and aft adjustment Side to side adjustment High-Performance Waterproof XL-5™ Electronic Speed Control Innovative waterproof design Sport Mode - forward / brake / reverse Race Mode - forward / brake Training Mode™ - 50% forward / brake / 50% reverse (patented) Traxxas EZ-Set® one-button setup LiPo and NiMH compatible with two-stage low-voltage detection Titan® 550 Motor Powerful Titan 12T 550 modified motor with internal cooling fan Oversized armature for big torque and increased power handling Virtually maintenance-free operation Fixed gear mesh motor plate makes setting gear mesh simple with 11 different gearing positions Molded wire retainer keeps motor wires secure Traxxas Stability Management® (TSM) Improves straight line acceleration and braking on low-traction surfaces Maintains steering composure to allow throttle-on powerslides Never dulls throttle or slows the vehicle Adjusts from off to 100% assistance from the transmitter TQi™ 2.4 GHz Radio System 2-channel transmitter 5-channel micro receiver (6533) with fail-safe security and integrated telemetry ports Compatible with optional TQi Traxxas Link Wireless Module (6511) to access full Traxxas Link app functionality (sold separately) Automatically stores and loads settings for up to 30 Traxxas Link-enabled models Programmable multi-function knob Patented O-ring sealed watertight receiver box keeps the micro receiver dry Low Center of Gravity (Low CG) Chassis Positions weight low for improved handling Smooth underside resists drag and snags Angled front bumper improves approach angle Improves rigidity and tightens tolerances Allows for easy maintenance Adjustable Battery Hold Down Easy, secure battery installation Swivels to allow different height batteries Locks securely without pins or parts to lose Efficient Direct All-Wheel Drive Full-time shaft driven 4-wheel drive Aluminum center driveshaft Once-piece steel axles Direct drive Sealed, silicone-filled differential Brushless ready for easy Velineon brushless power upgrade Steering High-torque waterproof Traxxas 2075 steering servo Precise servo saver integrated into servo horn High steering angle option High Performance Suspension Captured links won’t pop off Geometry tuned for precise handling Dual rear camber link mounts Adjustable droop Springs and Shocks Fully adjustable oil-filled Ultra Shocks™ with X-ring technology Red powder coated shock springs feature a responsive spring rate Wheels and Tires Black Chrome split spoke wheels High-performance tires with long-wearing compound Wider rear tires for a more aggressive stance Replica brake discs incorporate standard 12 mm wheel hexes Brake calipers can be mounted in forward or trailing edge positions Rubber-Sealed Ball Bearings Precision Hex Hardware Backed by Unparalleled Traxxas Support and Parts Availability Requires Battery and Charger (Sold Separately)
