Currency
US Dollar (USD)
Model Name:
Desert Racer
Model Type:
Short Course Trucks
Model Speed:
30+ mph (with 4s LiPo), 50+ mph (with 6s LiPo)
Model Skill Level:
5
Pro-Scale®
13.4 pounds (6.1 kg)
27.32 inches (694 mm)
13.57 inches (345 mm)
Front Track:
Rear Track:
10.29 inches (261 mm)
16.53 inches (420 mm)
Center Ground Clearance:
2.27 inches (58 mm)
Drivetrain:
Shaft-driven 4WD
Transmission:
Direct-drive with Torque-Biasing Center Drive
Sealed, 4-gear (front), locked spool (rear), sealed, 4-gear (1M weight oil) (center)
Gear Ratio (Internal):
17.89:1
32 pitch
Servo(s):
2075R metal gear, digital high-torque waterproof
Battery Compartment Specs:
181 mm X 46 mm X 56 mm
Motor Name:
2200 kV
Motor Type:
Sensorless brushless
Motor Weight:
14.32 ounces (406 g)
Motor Length:
2.97 inches (76 mm)
Motor Diameter:
1.65 inches (42 mm)
Motor Shaft Size:
5 mm
Motor Connector Type:
6.5 mm bullet
ESC Name:
Velineon® VXL-6s
ESC Type:
Brushless
ESC Case Size:
2.28 inches (58 mm) / 2.83 inches (72 mm) / 1.81 inches (46 mm)
ESC Weight:
7.30 ounces (207 g)
Motor Connectors:
6.5 mm bullet
Battery Connectors:
Large Pro-Scale® Body with Highly Detailed Replica Parts Heavy-duty truck body mounts to chassis in multiple locations Strong and functional tube frame mimics full-size off-road racers Detailed interior cabin with driver figures Replica brake calipers and discs with integrated 17 mm wheel hubs Two fully-functional spare tires and functional spare driveshaft Highly detailed replica parts: fire extinguishers, shock reservoirs, jack, and tools Realistic side plates mount to tube frame VXL-6s™ Waterproof Electronic Speed Control 6s LiPo compatible Integrated cooling fan Real-time telemetry via Traxxas Link™ Machined heat sink 3-LED status indicators Powered accessory ports 10-gauge silicone wire Velineon® Brushless Motor 4-pole 2200 kV brushless motor 5 mm output shaft Finned can for better heat dissipation Traxxas Stability Management® (TSM) Improves straight line acceleration and braking on low-traction surfaces Maintains steering composure to allow throttle-on powerslides Never dulls throttle or slows the truck Adjusts from off to 100% assistance from the transmitter TQi™ 2.4 GHz Radio System 2-channel transmitter 5-channel micro receiver (6533) with fail-safe security and integrated telemetry ports Compatible with optional TQi Traxxas Link Wireless Module (6511) to access full Traxxas Link app functionality (sold separately) Automatically stores and loads settings for up to 30 Traxxas Link enabled models Adjustable steering and throttle sensitivity (exponential) Adjustable steering and throttle endpoints Patented waterproof receiver box with easy-access plug Chassis Makes maintenance easier Tough skid plates protect critical components Fully integrated tube frame for scale appearance and added rigidity Lowers center of gravity (CG) for improved handling Allows easy access to components Reinforced bumpers to absorb impacts ESC battery plugs hard mounted to chassis Innovative Battery Compartment Accommodates single 4-cell LiPo or dual 2-cell or 3-cell LiPo batteries Opens from underneath without removing body Fixed oversize battery strap locks batteries securely into place Separate skid plate to protect batteries Transmission All-steel gear direct drive transmission Torque-Biasing Center Drive™ Removes as a single piece for easy maintenance Fixed-pin gear mesh system Drivetrain Steel CV driveshafts (front) with 6 mm stub axles Steel straight axle (rear) Oil-filled limited slip front differential Locked steel spool (rear) Heavy-duty splined front driveshaft Fixed-length steel rear driveshaft Steering Chassis mounted 2075R metal-gear servo Dual bellcrank design with bearings and integrated servo saver Solid non-adjustable steering links for rugged durability Suspension Provides scale looks and authentic off-road driving dynamics Tough independent double-wishbone front suspension with captured rod ends Triangulated 4-link rear suspension with solid rear axle (patent pending) Tough composite trailing arms Steel upper links with 3 optional positions for suspension tuning Eight long-travel aluminum GTR shocks; four with springs and adjustable ride height collars Realistic and functional front and rear sway bars Detailed functional limit straps on rear axle Wheels and Tires Replica BFGoodrich® KR3 off-road tires Beadlock-style 17 mm dual-diameter wheels Sealed Ball Bearings Hex Hardware with Rust-Resistant Black Oxide Coating Requires Battery and Charger (Sold Separately)
