Please create a new account
Sign Up Here
Learn more.
Learn more.
Small-scale adventure takes a big leap in performance with TRX-4M High Trail™ Edition trucks. Available with either a Chevrolet® K10 or Ford® F-150® body, High Trail trucks offer over 35% more center ground clearance than a standard TRX-4M. Both trucks ride on larger Mickey Thompson® Baja Pro™ XS tires with an extended wheelbase for even more all-terrain capability. From indoor fun to outdoor adventure, TRX-4M High Trail Edition pickups deliver the quality and performance you expect from Traxxas.
Long Arm Lift Kit
The High Trail edition’s Factory Installed Long Arm Lift Kit and larger tires raise the center ground clearance over 35% for a dramatic lifted stance. Revised shock mounts and extended links ensure the truck maintains its carefully-tuned suspension geometry for peak performance on challenging terrain.
New Larger 2.4" Tires
Larger 2.4″ Mickey Thompson® Baja Pro™ XS replicate the full size tire’s aggressive tread pattern and fill out the High Trail Edition’s wheel wells for an authentic “lifted truck” look. Sticky compound rubber gives extra “bite” for superior traction on the trail.
Extended Wheelbase
The High Trail Edition’s steel frame rails extend the wheelbase out to 162 mm to capture the pickup’s real-world proportions perfectly. A longer wheelbase also translates into greater climbing stability and a smoother, more stable ride over rough terrain.
DETAILED CLIPLESS BODY
The High Trail’s clipless body holds tight on the trail but releases in just seconds with a hidden latching system to preserve its clean lines. The tough ABS body featured molded-in color with highly detailed chrome trim for complete scale authenticity.
Video
F-150
K10
Innovation
High Trail Edition’s Long Arm Lift Kit expands the core features and capabilities of the standard TRX-4M while maintaining its trail-bred suspension geometry.
Lifted Performance
TRX-4M High Trail Edition’s Long Arm Lift Kit and oversize Mickey Thompson tires raise the center ground clearance 35% higher than the standard truck. Extended links maintain TRX-4M’s superior suspension geometry.
Enhanced Versatility
TRX-4M provides all the fun and versatility of a compact crawler without any of the limitations. TRX-4M is larger and yet more maneuverable than 1/24 scale vehicles with its tighter turning radius. The High Trail Edition’s oversize tires and superior center ground clearance open the door for tough off-road terrain and big challenges.
Extended Steel Ladder Frame
TRX-4M High Trail Edition performs like a full-size crawler because it’s built like one. A new extended rigid steel ladder frame runs from bumper to bumper to virtually eliminate flex. You’ll feel the added stability of its longer wheelbase on steep climbs or while navigating technical terrain.
Trail-Ready Chassis & Driveline
High Trail Edition trucks ride on a sophisticated four-link suspension with extended heavy duty linkages. Spool-equipped solid axles supply non-stop climbing power with excellent articulation and extended center ground clearance to climb over the toughest obstacles. Heavy duty telescoping center driveshafts send the motor’s torque to the axles with a smooth-running CV design.
Tight Turning Radius
TRX-4M outmaneuvers much smaller trucks thanks to its exceptional 45° steering angle—an impressive feat considering its larger and more versatile size.
Detailed ABS Bodies
Constructed out of tough ABS, TRX-4M High Trail Editions faithfully captures all the details of these classic Ford and Chevrolet pickups in exacting 1/18 scale. Tinted windows, chrome trim, a pickup bed, and other molded body accessories give them a truly authentic appearance.
LED Headlights
Standard LED headlights enhance the High Trail’s scale appearance and create new avenues for fun as you challenge your driving skills through sofa-cushion tunnels or over garden obstacles when the sun goes down.
Soft-Compound Tires
Large 2.4? Mickey Thompson Baja Pro XS tires give High Trail Editions that lifted truck look. The oversize tires improve the center ground clearance and put more rubber to the ground for exceptional off-road performance. Detailed 8-hole chrome mag wheels round out the package for a stunning scale appearance.
Waterproof Electronics
You’ll never need to change course to avoid puddles, mud, or snow with lifted High Trail Edition trucks. We built TRX-4M for all-weather adventure with fully-waterproof electronics.
Innovative New Electronics
The all-in-one ECM-2.5™ incorporates all the features of an XL-5™ speed control, TQ receiver, and Pro Scale® Lighting Control Module into one sleek waterproof package. The ECM-2.5 features three realistic driving modes with smooth, precise control and outstanding throttle response.
Titan® 180 87T Motor
The powerful 87-turn Titan 180 motor delivers precise low-speed torque to propel TRX-4M’s oversize tires up and over technical obstacles. On the trail, TRX-4M offers surprising speed to keep pace as you walk alongside to find the next challenge.
High Capacity LiPo Battery and Fast Charger
A high-capacity 750 mAh 2-cell LiPo battery provides over an hour of runtime with 7.4 volts of high-performance power and Traxxas iD® safety and simplicity. The included USB-powered charger provides quick and reliable fast charging at up to 2-amps of charging capability.
TQ Transmitter
TRX-4M comes with a full-size TQ transmitter for all-day comfort, reliability, and precise long-range control.
Details
Realistic Body Elements
Traxxas took great care to replicate these classic pickups in 1/18 scale. Chrome bumpers, side mirrors, door handles, and even wipers are molded in exacting detail for exceptional scale realism.
Detailed 1.0" Wheels
The High Trail’s replica 1.0" wheels are authentic scale reproductions of classic chrome mag wheels. TRX-4M utilizes a standard 7 mm hex, making wheel swaps quick and easy.
LED Lighting
High Trail trucks feature standard LED headlights in the front grille. Add optional Pro Scale LED lights and K10 comes to life with functional brake lights, reverse lights, and even emergency flashers (Pro Scale lights sold separately).
Included 2s LiPo Battery with iD®
The included 2-cell LiPo battery provides 7.4 volts of high-performance power and over an hour of runtime with Traxxas iD® safety and simplicity. The specially-designed iD connector plugs directly into the ECM-2.5.
2-Amp USB Fast Charger with iD®
The included 2-amp USB-A charger provides fast and convenient charging almost anywhere. Traxxas iD technology is the easier and safer way to charge LiPo batteries. Just plug the iD battery in and the charger does the rest. When the LED light turns green, the battery is charged.
Clipless Body Mounting System
Traxxas’ innovative clipless body mounting holds the replica bodies firmly in place no matter how rough the action gets. A quick pull on the hidden clips releases the body in seconds, with no body clips to lose or messy hook and loop tape.
High-Performance Tires
Licensed Mickey Thompson Baja Pro XS tires are accurate down to the smallest detail with an authentic lug pattern and raised sidewall lettering.
Triangulated Four-Link Suspension
TRX-4M High Trail Edition rides on a lifted four-link suspension with heavy duty triangulated rods. Solid front and rear axles provide excellent articulation to climb over the toughest obstacles.
Heavy Duty Center Driveshafts
TRX-4M’s heavy duty center driveshafts telescope freely to allow maximum suspension travel. Smooth-running CV joints are engineered for long-lasting, trouble-free performance.
Spool-Equipped Front & Rear Axles
TRX-4M’s front and rear axles are locked with spools to supply non-stop climbing power to all four wheels. Tough, steel constant-velocity (CV) joints allow increased steering angle at the front wheels for tight turns.
Oil-Filled GTM Shocks
TRX-4M’s oil-filled GTM shocks feature dual O-ring seals at the shaft for a perfect seal and smooth performance. Tuned specifically for the TRX-4M, GTM shocks smooth out bumps for a realistic and controlled ride.
ECM-2.5 Electronic Control Module
ECM-2.5 features low voltage detection for 2s LiPo batteries and EZ-Set® one-button programming to select driving modes. Choose Sport Mode for all-around driving, or Trail Mode for smooth drag braking on steep descents. For a smooth scale look while creeping over technical terrain, Crawl Mode applies full brakes the instant the throttle is released and allows drivers to continue through to reverse without a second push on the trigger.
Low-CG Battery Tray
TRX-4M’s battery tray lies deep in the chassis to concentrate weight as low as possible. A lower center of gravity increases stability and reduces the risk of a rollover. A wide rubber strap keeps the battery safely locked in place and prevents the weight from shifting.
Optional Transmission Ratios
TRX-4M’s modular assembly allows you to swap out different transmissions to change the performance characteristics of the truck. Install the low-range transmission for smooth low-speed torque or boost your top end with the speed gearing option (optional ratios sold separately).
Steel C-Channel Frame Rails
The High Trail Edition’s extended heavy duty frame rails are formed with a deep C-channel for maximum rigidity. The rails are taller through the middle section for increased strength where it’s needed most.
Forward-Mounted Motor
The Titan® motor mounts securely to the transmission module with a fixed gear mesh that never needs adjustment. The motor’s mounting position shifts the weight bias forward for improved crawling dynamics over obstacles.
Heavy Duty Steering Servo
TRX-4M’s heavy duty 2065T servo operates on full 6 volt power with a metal main gear for precise control and powerful steering authority. The rugged one-piece drag link sits high up in the axle to avoid snags and impacts.
High-Quality Hardware
TRX-4M rides on low maintenance self-lubricating bushings for long lasting performance. TRX-4M is assembled with high-quality hex hardware for long-term durability and secure fastening.
Black Edition
This Special Black Edition 1/18 TRX-4M® Chevrolet® K10 High Trail features custom black paint and chrome accents for a unique look. Now available worldwide!
Traxxas makes a full line of high-performance parts and detailed accessories to get the most out of your TRX-4M. Compatibility and fitment are never an issue when you buy genuine Traxxas products.
