Please create a new account
Sign Up Here
Learn more.
Learn more.
The High Trail edition’s Factory Installed Long Arm Lift Kit and larger tires raise the center ground clearance over 35% for a dramatic lifted stance. Revised shock mounts and extended links ensure the truck maintains its carefully-tuned suspension geometry for peak performance on challenging terrain.
New Larger 2.4" Tires
Larger 2.4″ Mickey Thompson® Baja Pro™ XS replicate the full size tire’s aggressive tread pattern and fill out the High Trail Edition’s wheel wells for an authentic “lifted truck” look. Sticky compound rubber gives extra “bite” for superior traction on the trail.
Extended Wheelbase
The High Trail Edition’s steel frame rails extend the wheelbase out to 162 mm to capture the pickup’s real-world proportions perfectly. A longer wheelbase also translates into greater climbing stability and a smoother, more stable ride over rough terrain.
Detailed Clipless Body
The High Trail’s clipless body holds tight on the trail but releases in just seconds with a hidden latching system to preserve its clean lines. The tough ABS body featured molded-in color with highly detailed chrome trim for complete scale authenticity.
Video
F-150
K10
Innovation
High Trail Edition’s Long Arm Lift Kit expands the core features and capabilities of the standard TRX-4M while maintaining its trail-bred suspension geometry.
Lifted Performance
TRX-4M High Trail Edition's Long Arm Lift Kit and oversize Mickey Thompson tires raise the center ground clearance 35% higher than the standard truck. Extended links maintain TRX-4M's superior suspension geometry.
Enhanced Versatility
TRX-4M provides all the fun and versatility of a compact crawler without any of the limitations. TRX-4M is larger and yet more maneuverable than 1/24 scale vehicles with its tighter turning radius. The High Trail Edition’s oversize tires and superior center ground clearance open the door for tough off-road terrain and big challenges.
Extended Steel Ladder Frame
TRX-4M High Trail Edition performs like a full-size crawler because it’s built like one. A new extended rigid steel ladder frame runs from bumper to bumper to virtually eliminate flex. You’ll feel the added stability of its longer wheelbase on steep climbs or while navigating technical terrain.
Trail-Ready Chassis & Driveline
High Trail Edition trucks ride on a sophisticated four-link suspension with extended heavy duty linkages. Spool-equipped solid axles supply non-stop climbing power with excellent articulation and extended center ground clearance to climb over the toughest obstacles. Heavy duty telescoping center driveshafts send the motor’s torque to the axles with a smooth-running CV design.
Tight Turning Radius
TRX-4M outmaneuvers much smaller trucks thanks to its exceptional 45° steering angle—an impressive feat considering its larger and more versatile size.
Detailed ABS Bodies
Constructed out of tough ABS, TRX-4M High Trail Editions faithfully captures all the details of these classic Ford and Chevrolet pickups in exacting 1/18 scale. Tinted windows, chrome trim, a pickup bed, and other molded body accessories give them a truly authentic appearance.
LED Headlights
Standard LED headlights enhance the High Trail’s scale appearance and create new avenues for fun as you challenge your driving skills through sofa-cushion tunnels or over garden obstacles when the sun goes down.
Soft-Compound Tires
Large 2.4? Mickey Thompson Baja Pro XS tires give High Trail Editions that lifted truck look. The oversize tires improve the center ground clearance and put more rubber to the ground for exceptional off-road performance. Detailed 8-hole chrome mag wheels round out the package for a stunning scale appearance.
Waterproof Electronics
You’ll never need to change course to avoid puddles, mud, or snow with lifted High Trail Edition trucks. We built TRX-4M for all-weather adventure with fully-waterproof electronics.
Innovative New Electronics
The all-in-one ECM-2.5™ incorporates all the features of an XL-5™ speed control, TQ receiver, and Pro Scale® Lighting Control Module into one sleek waterproof package. The ECM-2.5 features three realistic driving modes with smooth, precise control and outstanding throttle response.
Titan® 180 87T Motor
The powerful 87-turn Titan 180 motor delivers precise low-speed torque to propel TRX-4M’s oversize tires up and over technical obstacles. On the trail, TRX-4M offers surprising speed to keep pace as you walk alongside to find the next challenge.
High Capacity LiPo Battery and Fast Charger
A high-capacity 750 mAh 2-cell LiPo battery provides over an hour of runtime with 7.4 volts of high-performance power and Traxxas iD® safety and simplicity. The included USB-powered charger provides quick and reliable fast charging at up to 2-amps of charging capability.
TQ Transmitter
TRX-4M comes with a full-size TQ transmitter for all-day comfort, reliability, and precise long-range control.
