Please create a new account
Sign Up Here
Learn more.
Learn more.
After 25 years, the Bronco returns as Ford’s top-performing 4X4 and America’s most sought-after SUV. Traxxas captures the eagerly-anticipated Bronco in exacting detail with all the capability and versatility of the award-winning TRX-4. The Traxxas Bronco combines Ford-approved realism and class-leading performance for exciting off-road adventure no matter where the trail takes you.
A Traxxas TRX-4 or TRX-6 with genuine Traxxas LED lighting is always the most realistic rig on the trail, and there’s no better, brighter way to go off-road after dark. The new Pro Scale Advanced Lighting Control System adds exciting new capabilities to your LED-equipped TRX-series truck, and puts you in control of the lighting setup with pushbutton ease. When you install the Pro Scale system, your truck will look and operate more authentically than ever.
The new Pro Scale Winch puts the TRX-4 and TRX-6 even further over the top as the most full-featured and authentic trucks on the trail. The new winch performs as realistically as it looks, and is a truly functional tool for off-road exploration and adventure. The included fob-style remote allows you to extend and retract the high-strength winch line with the touch of a button. The rugged, heavy-duty hook is made of metal for reliable performance and lasting durability, and the high-torque motor gives the winch a 10-pound maximum capacity. That’s plenty of pull to get your machine out of trouble, conquer impossible terrain challenges, and assist other trucks.
QUICK FEATURES ON PRO SCALE WINCH (#8855)
Full-function, remote-operated Line In and Line Out control
10-pound maximum weight capacity
Over four feet of high-strength reinforced line with rugged steel hook
Convenient fob-style remote with two user-selectable channels
Free spool feature allows fast line extraction manually
Overload protection prevents overheating
Compatible with all TRX-4 and TRX-6 models
Built-in electronics for easy installation
Single-wire hookup does not require receiver access
Additional mounting holes for flat-surface installation
Easy to adapt to custom builds and aftermarket bumpers
