To properly use the 2 or 4-Amp DC Peak-Detecting charger that is included with your Traxxas vehicle, simply follow these steps.
- Plug the charger into a 12-volt automotive auxiliary power socket or the optional Traxxas AC to DC Power Supply Adapter (#2976). When the charger is ready to begin charging the LED will glow a solid red.
- Connect the battery to begin charging. Charging is represented by a green flashing / blinking LED light. (See Charge Progress chart)
- Disconnect the battery when charging is complete. When the battery is fully charged the LED will glow a solid green.
See the Charger Progress and LED Indication charts below for more information.
Charge Progress | |
1 green flash | 0-25% charged |
2 green flashes | 25-50% charged |
3 green flashes | 50-75% charged |
4 green flashes | 75-100% charged |
Solid Green LED | 100% charged |
LED Indication | Meaning |
Solid Red LED | Ready for Charging |
Slowly Flashing Green LED | Charging (see Charge Progress chart) |
Solid Green LED | Battery Fully Charged |
Flashing Red LED | Charger Error (see Charger Error Codes below) |
No LED | No power (check power source or DC plug fuse) |
If there is an issue with the battery or charger the charger's LED will flash or blink red. Refer to the Charger Error Codes chart below for more information.
LED Indication | Meaning | Solution |
1 red flash | Power Source Error | Check power source and DC plug fuse |
2 red flashes | Battery error | Disconnect battery |
3 red flashes | The charger safety timer has expired | Disconnect battery; if battery is too hot, discontinue charger use and contact Traxxas Customer Support |
4 red flashes | The internal charger temperature is too high | Disconnect charger and allow charger to cool |
7 red flashes | The battery voltage is too high | Disconnect battery; battery is not compatible with the charger |
To determine if the fuse is responsible for an error code, use the following steps to check the fuse.
- Unscrew the end of the DC plug.
- Slide the fuse out. Note: Be careful to keep the cap end of the charger together. Also, keep track of the spring that is on the other end of the fuse inside the charger.
- Insert new 5A Buss fuse. If the fuse is good, reinsert the fuse. Note: Be sure to place the spring in the charger before inserting the fuse.
- Screw the end of the DC plug back on.
