Maximum Performance for Your Hoss 4X4 VXL
New extreme heavy-duty steel CV (constant velocity) driveshafts for the Hoss 4X4 are engineered Traxxas-Tough™ for our most demanding and extreme fans. Designed specifically for monster truck applications, these new shafts are built to withstand the brutal, wheel-standing torque of Hoss’ 540XL motor and the massive grip of the huge Sledgehammer tires. Compared to ordinary metal shafts, Traxxas’ unique, splined telescoping design delivers full-range articulation, so there is never a need to limit suspension travel. Since they are made by Traxxas, you can count on easy installation and perfect fit in your Hoss 4X4, Slash 4X4, Rustler 4X4, and Stampede 4X4 models.
Built for the Extreme
The heavy-duty splined telescoping steel shafts offer maximum articulation with huge 10 mm CV balls and large-diameter hardware. Metal pin-retention rings keep the drive pins securely in place for extra security on high RPM speed runs.
Fits the Following Models:
