Whether you've just wrapped up performing some maintenance and cleaning oryou opened the box to your new Traxxas R/C vehicle it's a good idea to checkthe receiver antenna for proper length.
The antenna wire runs from the receiver inside the receiver box to theantenna tube. The antenna wire feeds into the antenna tube which has a blackcap at the end. Some models feature an antenna that stays inside the body whileothers may stick up through the body. The following information is applicableto whichever type of setup is on your R/C vehicle.
The antenna wire is black, and at the end of the wire you will see a silvermetal piece with a translucent wire coming out. **DO NOT cutthe translucent section or metal piece from the antenna. Doing so willsignificantly hinder the effective radio range.**
Feed the antenna wire up the antenna tube. Look for the translucent end ofthe wire; it should be even with or slightly below the top of the tube. Put theblack antenna cap on and secure the antenna tube in the proper location. Ifthere is excess antenna wire and it seems to be too long simply feed thatsection into the receiver box, and you're done.
  • Do not kink the receiver's antenna wire. Kinks in the antenna wire will reduce range. If using 'zip-ties' do not pull them too tight, this will cause kinks.
  • DO NOT CUT any part of the receiver's antenna wire. Cutting the antenna will reduce range.
  • Extend the antenna wire in the model as far as possible for maximum range. It is not always necessary to extend the antenna tube out of the body. If coiling the antenna wire is required do not create sharp bends in the wire, a coil should make a smooth circle.
  • Do not allow the antenna wire to extend outside the body without the protection of an antenna tube, or the antenna wire may get cut or damaged, reducing range. It is recommended to keep the wire inside the body (in the antenna tube) to prevent the chance of damage.
