Upgrade Your 2WD Slash, Rustler, Stampede, or Bandit
Developed specifically for the hard-hitting Drag Slash, the Pro Series Magnum 272R upgrades key features of the standard Magnum transmission for maximum durability and next-level performance. A new low-profile design, 3.2 mm motor plate and hardened steel top shaft are just the beginning. The Pro Series Magnum 272R represents a complete performance redesign and now it’s available for your standard or VXL 2WD Bandit, Rustler, Stampede, or Slash.
Magnum 272R Transmission
QUICK FEATURES ON PRO SERIES MAGNUM 272R TRANSMISSION (9495)
  • Redesigned transmission case
    • Reinforced for added strength and rigidity
    • Low-CG design for improved handling
    • Ultra-rigid wheelie bar mount
  • 3.2 mm Aluminum Motor Plate
    • Increases structural rigidity
    • Improves heat dissipation
    • Compatible with fixed gear mesh system
  • Hardened-steel top shaft
    • Press-fit top gear for superior strength and durability
  • Sealed differential
    • Hardened-steel beveled gears
    • Tunable with silicone differential oil
  • Easy access differential
    • Simple removal for tuning and maintenance
More Popular Accessories for Your Ride
Get the latest in high-performance parts and accessories made by Traxxas, for Traxxas. Whether you're building a backyard bruiser or a top-speed racer, Traxxas parts and accessories help you extract the most performance from your vehicle.
6768G
Anaconda® Street Tires
with Green RXT Wheels
(2WD rear)
6775G
Anaconda Street Tires
(4X4 F/R, 2WD fr only)
6768G
w/ Orange RXT Wheels
(2WD rear)
6775A
3767T
Orange Aluminum Shock Caps (fits Ultra Shocks)
3678T
Orange Assembled Wheelie Bar (fits 2WD models)
3741T
Orange Aluminum Turnbuckle Set (39 mm & 49 mm)
3632T
Orange Aluminum Caster Blocks (6061-T6, 30-degree)
