Upgrade Your Slash's Speed and Durability in Three Easy Stages
The Traxxas Slash is the essential RC short-course truck. It’s the original, the best-seller, and one of the most popular Traxxas models of all time. Fast and feature-packed with Titan 550 power, the Slash arrives ready for 30+mph off-road action and is legendary for toughness. But “stock” is just the beginning for the Slash. With genuine Traxxas option parts, you can make your Slash an even faster, tougher, and more formidable machine. For this article, we’ll build up our Slash in three phases, topping it off with Velineon brushless power for tire-melting 60+mph performance!
Stock Traxxas Slash
Traxxas 8712 tool kit
You can use the tool kit that comes with the Slash to install all the parts in this article, but upgrading your tools can be just as important as your vehicle modifications. The Traxxas 8712 tool kit includes premium hex bits and nut drivers to perform upgrades or maintenance on your Traxxas model. The kit also includes an overmolded grip and convenient embroidered storage case.
Phase 1 - Heavy-Duty Suspension Arms
Required Items
  • 3631R HD Arms (front) - red
  • 2555R HD Arms (rear) - red
Add Phase 1 Accessories to your cart with one click!
The Heavy Duty nylon composite Traxxas developed for the E-Revo VXL and also put to work on the X-Maxx and Maxx trucks is now offered for Traxxas 2WD vehicles including the Slash. This material is formulated for extra strength in even in cold conditions that make other materials brittle. And, it comes in a variety of colors. You can get it red (like we’re using here), as well as blue, green, white, orange, and black.
Rear HD suspension arms
Front HD suspension arms
The red really pops, but note the revised shapes, also. The Heavy Duty arms’ new design balances rigidity and flex for maximum performance and durability.
Front HD arms installedFront HD arms installed
Rear HD arms installedRear HD arms installed
Phase 1 complete
Those red arms look really nice against the black and grey parts, and this Slash is now even tougher than before.
Phase 2: Aluminum Options and Servo Upgrade
Required Items
  • 3636X Aluminum steering blocks - red
  • 3632X Aluminum caster blocks - red
  • 3652X Aluminum rear uprights - red
  • 3743X Aluminum bellcranks– red
  • 2255 High-Torque 330 servo
  • 5862 Big Bore shocks
Add Phase 2 Accessories to your cart with one click!
Next, we’ll dial up even more durability and colorful style with aluminum option parts, and boost steering power, precision and durability with a 2250 High-Torque 330 servo. Like the HD arms, these components are direct replacements for the stock parts.
High-Torque 330 servoHigh-Torque 330 servo
Servo comparisonServo comparison
The High-Torque 330 servo is a real powerhouse, delivering 330 oz.-in. of torque—that’s more than three times the torque of the standard 2075 servo. A coreless motor and metal gears make it super-responsive and extra rugged, too. And of course, it’s waterproof.
Servo installation is easyServo installation is easy
Don't forget the servo saverDon't forget the servo saver
Vibrant red anodizing makes the steering blocks, caster blocks, bellcranks, and rear uprights shine. Compact parts like these are an ideal application for aluminum.
Red aluminum parts
Red aluminum steering blocks
Red aluminum axle carriers
Bonus Upgrade: Big Bore Aluminum Shocks
After adding the HD arms and aluminum suspension components, we couldn’t resist adding the Big Bore Aluminum Shock set. These beauties feature hard-anodized bodies with slick PTFE-coated bores for extremely long wear, and scuff-resistant Titanium Nitride-coated shafts that reduce friction on the X-ring seals to the absolute minimum. Progressive-rate springs and silicone shock oil are included, just fill ‘em up and bolt them on. The stock Ultra Shocks are excellent composite-body units, but the Big Bore’s hard-anodized bodies and TiN-coated shafts offer even slicker operation and longer wear. They look pretty cool, too.
5862 Big Bore Shocks5862 Big Bore Shocks
Shock comparisonShock comparison
Installed Big Bore shocksInstalled Big Bore shocks
Phase 3: Velineon Brushless Power-Up
Required Items
  • 3350R Velineon VXL-3s power system
  • 4725 25-tooth pinion gear
  • 4683 83-tooth spur gear
Add Phase 3 Accessories to your cart with one click!
Phases 1 and 2 went a long way toward improving the Slash's durability, appearance, and steering authority. Now it’s time to dramatically increase horsepower and speed, and we’ll do that with the Velineon VXL-3s brushless system. With the Traxxas Power-Up Program, you can trade in the Rustler’s stock XL-5 speed control and Titan 550 motor for a discount on the Velineon system. You can make the exchange by mail, or at your participating Traxxas dealer—get all the details here. Simply remove the XL-5 speed control and Titan 550, and replace them with the VXL-3s and 3500 motor. The VXL-3s has Sport, Race, and Training modes just like the XL-5, and it programs the same way.
VXL-3s speed control
Velineon Brushless motor
Stock Gearing Vs Brushless Gearing
For maximum performance, we’ll replace the Slash’s 16-tooth pinion and 90-tooth spur gear with a 23-tooth pinion and 86-tooth spur gear, as used by the Rustler VXL. The Velineon system will also work just fine with the stock gearing and your Slash will still go a lot faster, but not quite as fast as it can go with the VXL gearing.
Gear comparisonGear comparison
Stock Slash gearingStock Slash gearing
Velineon brushless gearingVelineon brushless gearing
Out of the box, the Velineon is set up for use with LiPo batteries with Low Voltage Detection turned on, as confirmed by the green LED when you turn the system on. If you’re using NiMH batteries, switch Low Voltage Detection off by pressing and holding the EZ-Set button until the LED turns from green to red.
Green light for LiPo batteriesGreen light for LiPo batteries
Red light for NiMH batteriesRed light for NiMH batteries
Don’t forget to let the world know your Slash is now Velineon brushless-powered! There’s a decal sheet in the box so the other guys can see what you’re packing.
Velineon decalsVelineon decals
Decals appliedDecals applied
Ready for action!This Slash is rad, red, and ready for high-output brushless off-road action!
