Take the Path Less Traveled.
Coming soon! Traxxas TRX-4® Scale and Trail® crawler is an all-new Traxxas design that instantly obsoletes the status quo with greatly expanded features, versatility, and capability. In other words, we built it the Traxxas way, rugged, powerful, and ready for fun! With availability in Mid-May, it’s arriving just in time for spring and summer outdoor action. Check out the features and images below to get the latest scoop on this incredible machine.
Be sure to enter your email address below to receive alerts, videos, photos, and fun information about features and availability as they become available.
AVAILABLE MID-MAY 2017!
Sign Up Now
Ultimate Ground Clearance
TRX-4 comes equipped right out of the box with Traxxas' game-changing portal axles. Portal axles lift the truck at the wheels for huge center pumpkin ground clearance. In order to achieve the same clearance with straight axles, your tires would need to be over an inch taller. Straddling boulders with ease, TRX-4 takes the path less travelled and leaves all the others behind.
Torque Twist Eliminated
The portal axles use gear reduction right at the wheels that dramatically reduces undesirable torque twist. Total axle gear reduction is over twice non-portal designs. The Titan® 550 motor torque is translated into straight, powerful, forward motion, rather than wasted energy twisting your rig right off the rocks.
Improved Geometry
Portal axle geometry raises the axle link mounts and center driveshaft, greatly reducing critical driveshaft and suspension link angles. This means less strain on the driveshafts, and the higher suspension links provide greater clearance with less scraping and dragging across the rocks. The steering drag link and tie rod are also raised up and out of harm's way.
Rigid Steel Frame
A heavy-duty formed-steel ladder frame with molded cross members creates an extremely rigid backbone that lets the suspension do the work it was designed to do. You’ll feel the difference on trails where the elimination of chassis flex allows for precise wheel placement when navigating technical terrain.
Remote Locking Differentials
Traxxas gives you the versatility to lock and unlock the front and rear differentials directly from your transmitter. Leave the differentials unlocked for relaxed driving on the trail. When the trail gets technical, lock the front and rear differentials, or just the front, for superior grip over extreme terrain. Sleeved micro cables control the differential action for scale appearance, without limiting suspension articulation.
45° Steering Angle
Traditional crawlers sacrifice turning radius for traction. TRX-4’s remote locking differentials disengage to take full advantage of its superior 45 degree steering angle. Once you clear the obstacle, re-engage the differentials for ultimate traction.
High/Low Range Transmission
When the going gets tough, use your transmitter to shift into low range for incredible 4-wheel drive pulling torque. Shift into high range for blasting down the trail. The plush suspension design absorbs rough terrain with ease and delivers outstanding scale appearance. Unmatched versatility makes TRX-4 adaptable to just about any situation or driving style.
Metal Gear Digital Servo
A new full-metal gear digital servo gives you the durability and steering authority you need to confidently and reliably power through tough situations.
Waterproof
Traxxas was the first to bring you fully waterproof RC vehicles years ago with our innovative designs. TRX-4 is fully waterproof for how you like to really play, not “splash resistant.” There is a big difference. Traxxas’ patented innovation gives you the freedom to tackle creeks, snow, and mud without worrying about water in your electronics.
Scale Detail
TRX-4 comes with the legendary Land Rover® Defender® body, complete with exciting scale details for an authentic 4-wheelin’ experience. We’ve included a functional spare, an off-road jack, and fuel canisters. Secure your gear in the roof basket. There’s even a snorkel for taking the waterproof TRX-4 through creek crossings. The rugged bumpers provide clearance and protection and are equipped with recovery D-rings.
Inner Fenders
The scale details did not stop with the body. Detailed inner fenders integrate with the floor pans and shock towers to keep rocks, mud, and twigs out of the chassis. The inner fenders are also equipped with pockets to install our optional LED rock light kit (sold separately) to light up the night trail. The integrated rock sliders help protect the body from damage.
Cruise Control
The Traxxas TQi radio system is equipped with cruise control for long-distance treks. Set your speed using the transmitter and then use the multi-function knob to fine-tune it faster or slower to precisely match the pace of your caravan of trail explorers. Cruise control makes it easy and comfortable for TRX-4 to be your companion for hours of driving fun and exploration.
3s Power System
The new XL-5™ HV speed control brings 3s LiPo capability for stronger, more efficient running. A new Trail profile facilitates smooth driving for most of your adventures, while a new Crawl profile introduces hill hold and instant reverse for extremely technical courses. Either will help you navigate obstacles with ease. Long run times, up to 2 hours, are possible with a Traxxas 3s 5000 mAh iD® LiPo battery pack!
Canyon Trail 1.9″ Tires
The 1.9″ Canyon Trail tires and tuned foam inserts are super-soft and grippy to deliver superior bite on rocky surfaces with convincing scale realism. The 12mm steel hex drive makes the TRX-4 chassis compatible with popular 1.9″ wheel and tire combinations.
Traxxas Tough
The TRX-4 chassis is built to handle the rigors of remote locations and all-day driving fun. The foundation begins with a pair of 1.5 mm thick steel frame rails. Large diameter steel links and heavy-duty rod ends keep the suspension firmly mounted. Hardened steel CV-style half-shaft joints are ultra reliable, while the brushless-ready steel portal axle and transfer case gears are smooth and quiet.
Aluminum GTS Shocks
All new oil-filled coil-over GTS shocks were created exclusively for the TRX-4 chassis. These silver-anodized aluminum units deliver silky-smooth damping performance and feature threaded shock bodies for easy ride height adjustments. The convincing scale realism looks great and they perform even better with an O-ring cap seal and dual X-ring shaft seals.
Extreme Capability
Steep approach angles front and rear allow TRX-4 to tackle big obstacles head on. The front motor design biases weight forward for superior climbing ability compared to other designs.
Additional Features
  • Sealed ball bearings
  • Hex hardware used throughout
Patents Pending
More Details Coming Soon
Photos and specifications subject to change.
Officially Licensed Product. Land Rover® Trademarks used under license to Traxxas, LP. Pending licensing approval.
