Outfitted with portal axles and high approach angles, TRX-4® set the standard for trail-conquering fun. Now you can upgrade your truck to a whole new level of off-road capability. Traxxas All-Terrain Traxx® for the TRX-4 redefine traction by allowing you to plow through mud, sand, and snow like never before. See the Traxx up close and in action as they take on some wild terrain in this new unboxing video.
The key to the Traxx' unbelievable grip lies in the enormous contact patch. The larger the contact patch, the more grip you have. Traxx distributes the load across a wide, all-terrain tread for unbeatable grip and traction. The large contact area also helps prevent Traxx from sinking or getting bogged down in soft surfaces like mud, snow, or sand. An adjustable tension mechanism keeps the treads tight while suspended road wheels allow Traxx to conform to surface irregularities for maximum traction. Offering over 16 mm of additional ground clearance, Traxx also improves the TRX-4’s rock-conquering ground clearance. Best of all, Traxx comes pre-assembled and ready to install on your TRX-4 in just minutes. Mount a set of All-Terrain Traxx to your TRX-4 and let your wildest off-road adventures come true!
TRX-4 Tactical Traxx rocks
TRX-4 Sport Rocks
TRX-4 Defender Traxx
TRX-4 Traxx  Sport snow
TRX-4 Blazer Traxx rocks
TRX-4 Traxx Bronco
← Previous Next →
