Replace the clutch in a Nitro 4-Tec
STEP 2: Remove the 20-groove pulley followed by the drive pin.
STEP 3: Remove the 2-speed spur gear cluster by sliding the assembly off the pulley shaft.
STEP 4: Remove the 2-speed clutch bell gear cluster. you'll need to wedge a screwdriver between the flywheel opening in the chassis and the flywheel in order to lock the flywheel. Remove the 3x10mm cap head screw with a 2.5mm hex wrench.
STEP 5: Remove the clutch bell gear cluster from the flywheel. Be careful not to lose the PTFE washer that slides over the clutch nut behind the rear clutch bell bearing.
STEP 6: Slide a screwdriver behind the clutch to assist in the removal.
STEP 7: Remove the clutch.
