How To Replace the Slipper Clutch in the Nitro Rustler
STEP 1: Remove the slipper clutch and spur gear by loosening the 4mm nylon lock nut.
STEP 2: Remove the large E-clip that secures the clutch bell to the flywheel.
STEP 3: Remove the clutch bell from the clutch assembly.
STEP 4: Wedge a thin blade screwdriver behind the clutch shoes and gently pull out the clutch.
