New Hard Compound Tires Make Drifting Easier Than Ever!
Traxxas introduces a new line of drift tires for the 4-Tec® 2.0. These hard-compound plastic tires provide the perfect combination of durability and breakaway potential for any drifting surface. Tough enough for carpet, concrete, or even asphalt, these tires hold up battle after battle. Precision-glued at the factory, Traxxas drift tires come pre-mounted on both narrow (front) and wide (rear) configurations. Choose from three colorful wheel options to customize your ride: orange, green, or black chrome.
Turn your 4-Tec into a Drifting Machine
With its rigid chassis and loads of horsepower, the 4-Tec 2.0 is the perfect platform for drifting battles. Drift like the cars in the video with just a few minor modifications. The 4-Tec’s high-angle steering option provides massive lock potential by trimming the bump stop and using the optional mounting hole for the linkage. The precise dual bellcrank steering and adjustable servo saver deliver silky smooth steering response and control. Add the optional differential spool (8379) to the rear differential for easy and predictable breakaway. Finally, be sure to add a set of new drift tires to your custom-painted body for that fully tricked-out look.
← Previous Next →
