Learn How Shock Placement Affects Your Suspension Setup
Part 2 of our Suspension Tuning Series covered how shock absorbers work, and the ways damping, spring rate, and ride height can affect handling. Next, we’ll talk about how the position of the shocks on the arms and shock towers can be used to tune the suspension, and explain how moving the camber link mounting points can alter cornering dynamics by changing “roll center.”
Tuning with Lower Shock Position
Each corner of your car or truck can be described as a lever (the suspension arm), a load (the shock, and the model’s weight the shock is supporting), and a fulcrum (the point where the shock pivots at the chassis). We can visualize this as lifting a weight with a lever as in the illustration below:
Load, lever, and fulcrumEach corner of the suspension system represents a lever, load, and fulcrum.
It’s easy to imagine how lifting the load will be easier if the load is placed closer to the fulcrum, and more difficult if the load is closer to the figure lifting the lever. The same principle applies to the suspension system. Moving the shock inboard (toward the chassis) on the suspension arm increases the leverage the suspension arm exerts on the shock, which makes it seem like the shock has softer springs and less damping. Moving the shock outboard (toward the wheel) has the opposite effect: the leverage of the suspension arm is reduced, making the spring and damping seem heavier.
Suspension arm shock holesChanging the lower shock position alters how much leverage the arm has on the shock.
Tuning with Upper Shock Position
If you watch the angle of the shock relative to the suspension arm as you move the arm from full down travel to full up travel, you’ll see the shock gets closer to perpendicular to the arm as it nears full up travel. As the shock gets closer to perpendicular, the spring acts more directly on the arm. In effect, the spring rate increases as the shock is compressed. This suspension has “rising rate” geometry. It allows the suspension to be “softer” and more responsiveness to small bumps and get progressively firmer to absorb bigger hits as the suspension is compressed.
Up and down travelNote how the shock “stands up” relative to the arm as the suspension is compressed.
Moving the top of the shock outboard (away from the chassis) will create maximum rate change between full extension and full compression. Moving the shock inboard will reduce the change in rate. Greater rate change can improve cornering on high-grip tracks, and improve control in rough conditions. Less rate change can improve traction in loose conditions and allow more responsive suspension action. As with all suspension tuning, the setting is a compromise and only testing can reveal the best choice for your terrain conditions and your driving style.
Upper shock holesChanging the shock’s top position alters how much the effective spring and damping rate changes as the shock is compressed.
Understanding Roll Center
The geometry of the suspension system’s arms and camber links creates a virtual point around which the chassis rolls—that’s “roll” as in “rotates around the X axis.” This point is called the roll center. The distance between the model’s roll center and its center of gravity (CG) effects how the model transfers weight when cornering.
Roll, pitch, and yawWhen we talk about the “roll” in roll center, we’re referring to rotation around an axis through the center of the model from front to rear.
Roll center is revealed by extending the suspension arm and camber link planes until they intersect, then drawing a line from the center of the tire’s contact patch to the intersection. The point where tire line crosses the centerline of the chassis is the roll center. Because roll center is determined by the geometry of the suspension arms and camber links and these are moving components, roll center is dynamic and changes with suspension movement.
Roll center illustrationExtending the arm and camber link planes and intersecting them with the tire’s contact patch reveals the roll center, which is below the chassis and its center of gravity.
When your model corners, inertia makes the chassis roll toward the outside of the turn. The chassis rolls because its CG is higher than the roll center. The distance between the roll center and the CG determines how resistant the chassis is to rolling. Lowering the roll center will increase the distance between the CG and roll center, which results in more chassis roll and increased cornering traction; raising roll center will reduce chassis roll and lessen cornering traction.
Chassis roll illustrationThe distance between the CG and roll center represents a lever that pushes the chassis to the outside of the turn. Raising the roll center shortens this virtual lever. A shorter lever means less leverage and less chassis roll (and vice-versa).
Roll centerFront and rear roll center do not have to match. The Slash 4X4 Ultimate’s front roll center is lower than the rear’s, which would give it more front grip (or less rear grip—it’s all relative).
That marks the end of the third installment. Click on the links below to see other installments of our Suspension Tuning Guide series
