TRX-4 Traxx Complete Set
$199.95
Traxx®, TRX-4® (4) (complete set, front & rear)
Pro Driving Tips
  • Use a high-output servo and High-Output BEC (2262) for maximum turning power in all conditions
  • Depending on how you use your Traxx, slight body trimming may be required
  • Use TRX-4 Long-Arm Lift Kit to minimize trimming and increase ground clearance
  • On TRX-4 models equipped with T-Locks, keep the front and rear differentials locked for optimal traction and performance
  • On TRX-4 models equipped with two-speed transmissions, always use low gear
  • Learn More
